TwistedCU
Active member
I was coming home from work tonight, hit the brakes, and the Jeep pulled a little bit to one side. After that, I noticed it was pulling to the right just driving. Then came the smell. I pulled over and there was smoke coming off my passenger side front brake pad. Not good. The caliper was locked up. The worst part is I must have took my 3/4" socket in with my tools last night after building a liftgate for my new hardtop (I'll put a pic later), so I couldn't even take the wheel off to check it out (no lug wrench - I just keep a socket and breaker bar in the console). I called AAA and brought her home on a hook. I guess I'm looking at 2 front calipers, and probably have to do the rotors & pads (pads were new 2 months ago, rotors were fine then). I hope the bearings are okay, but that remains to be seen. She was smokin' pretty good.
By the time the tow rig showed up, it came clear, the wheel spun freely, and brakes worked ok. I had it towed anyhow because I was a good 30 miles from home and figured it would just happen again.
Any advice on what to look for and what to check? I've never done brakes, calipers or even packed bearings, so I'm going into this with tools and a Chiltons. I figure if I did the lift, the brakes should be do-able!
