Well, here goes. This is probably going to upset some of you here, but I am turning my 1989 YJ into something it never was intended to be. Here in New York City, there are not any places to go off roading (so all of the lifted Jeeps you see here are all for show). There are a lot of people that enjoy drag racing, car shows, and cruise nights at various locations. I am one of those people. I was looking to build something that would be different. It had to have 4 seats, fun to drive, and short enough to park behind my other car in my driveway. One day when I was at a car show, I met someone that had a CJ with a small block Chevy engine in it, and it gave me an idea. A friend has a repair shop and offered me a lift to work on it, along with the help of his mechanics for welding and doing other major things that I couldn’t do. I took my Jeep in on December 9, 2008 for a simple drivetrain change. As I was leaving, my buddy came running up to me and mentioned to me that only a few bolts attach the body to the frame, and if we removed it we could clean up the chassis. I agreed, and my small rat-rod project mushroomed into a major frame off project. He knew I wanted to convert it to 2 wheel drive, and suggested that now would be the best time to do it (I planned on doing the suspension work in the second phase). Although I originally was going to use a Cherokee axle, another friend suggested going all out and using a straight front axle. I bought mine from Speedway Motors, complete with a 4 inch drop, disk brakes, etc. I had a 350 Turbo trans built by Select with reverse manual valve body and trans brake. Moon made my Ford 9 inch rear with 3.70 gears. The roll cage and suspension work is being done presently by Bobby Gardner at his shop in Hicksville, Long Island. The engine is 450 HP with timing gears, 10.5 compression, Crower cam, etc breathing through Advance fenderwell headers into cutouts (for easy noise) and Gibson round turbo mufflers.
The first picture shows how it looked when I bought it for $400.
From the side view, you can see that with the engine set back behind the front axle, this is truly a mid-engine vehicle.
Traction bar, rear, spring without lowering blocks IMG_7373 .JPG569.8 KB · Views: 3,079
