im wanting to lift my 88 yj enough for a set of 35s. i have thought of doing a spring over but i am scared of axle wrap does any one have any sugguestions on what to do and how hard is it do it
An alternative would be a 4.5 SUA kit, 1" BL and some TJ flares, but...
Although axle wrap is a factor with a SOA, don't let it scare you away from doing it. Worse comes to worse you can get some traction bars. There is at least one set that has quick disconnects out there, but I can't recall who makes them.
You are going to need at least 6-7 inches of lift. If you by a kit get the RE 4.5" (IMO the best kit on the market)and put a 2" BL. Depending on the tires you choose there may still be a little rubbing at full stuff..Alot of tires are smaller then the say(unless you go swampers)
