Hunting down a miss is difficult. It could be expensive if like yourself you change things before verifying they are bad.
How bad is the miss? Post up a video recording of the running engine driver side of the engine capturing the miss.
No if its past the CAT it should not be an issue. Before the CAT it gives the CAT wrong O2 readings and changes the O2 mixture.
This is something you should be able to see with a OBDII reader.
The 99 and earlier exhaust manifolds tend to crack on first or last cylinder
Replacementl like the below correct it. Is your miss a exhaust leak or an intake leak?
Im not saying change your intake. I will always say prove out what is wrong before swapping. Im just saying the stock is known to crack.
Thee are plenty other reasons for the pum pum sound that is not tripping a misfire code 0300 thru 0306.
These are difficult to track down. Post up a video of the. Noise.
With the engine running very carefully take the longest screwdriver and place it on the back of each injector. No long hair, hoodie strings or lanyards chains or anything dangling from your body. Lean in and place your ear on the back of the screwdriver. You should hear clicking. The clicks are the injectors firing. If any are not this could be a stuck injector.
Another cheap if not near free thing is to sea foam the engine or steam it to clean carbon off of the cylinders and valves. This goes along with changing spark plugs, cleaning grounds, and TB +IAC every 30k miles.
Once cleaned every few thousand miles drive s quarter mile with the engine up at 3300 rpm or just higher. This knocks off carbon and gives the valvs a chance to spin in their seat farther reducing buildup.
I take it you mean Seafoam the crank case?
Did that. Ran the whole can, let the Jeep sit for 20 minutes, drove it hard as heck for about 30 minutes. No smoke. Or it was so minor I didn't notice it.If you followed the process and let it sit 15 min off and soak you will get some smoke.
If you run it out. And continue to burn it out without setting then you will not get smoke
The stethoscope says all injectors are clicking, and at the same rate. Tried with the probe against pretty much every surface of that engine that I could reach and I can't hear the miss from anywhere, but it's there.
Discovered that one of the ears that the distro cap bolts to on the distributor is broken and the cap has been loose. I reattached with a longer bolt and a nut, still missing.
I tried to get an audio recording but the forum won't let me post them here. Seeing what I can do.
I'm not sure what else to do at this moment other than getting my fuel injectors cleaned.
“Sounds” like unfounded advice.
Data talks!!! Where is the proof?
