more power?
busta
i need to know a cheap way to get more power out of my 2.5 with 33's. can anybody help me?!? i know new gears but what else?
Put one of those "magic" mufflers that the tuner guys use.. they seem to make tons of horsepower..or at least make alot of...sound and stuff:lol: :lol: :lol:
Seriously..can't help on the 2.5 problem without recomending a swap.
But want to welcome you to Jeepz!!
There's lots of things you can do that make a little difference, but all together they help out.
Hmmm, cheap...
Remove the factory airflow restrictor, put a "drop in" K&N filter in, change out the mechanical clutch driven fan for an electric one (cheap if you use a junkyard fan from a Taurus, about $200 to do a flex-a-lite FLX475), Use synthetics in the diffs, transmission, and transfer case
Not as cheap...
Cat-back exhaust, 4.0L throttle body (again junkyard ;) ), roller rockers,
Gears really are the correct solution though.
TC's got it right.......gears! Other than that, a V8 would add tons of power, of course!!:D Hey, from a fellow 4-banger, just get 'er off the pavement and the little 4 does just fine.
Well even though gears are the best solution, they are not cheap like you want. Put a K&N in the stock box, do a good tune with quality stuff, use synthetics like TC suggested, and drive it like you stole it. U can get a 4.0 throttle body for real cheap ($50-$60), though I dont think they make an enormous difference, but then again, nothing on the 2.5 does.
I pulled the intake restrictor tube, added a Flex-a-Lite electric fan, put in some Bosch Platinum Plus4 plugs, and just ordered a throttle body spacer. Without the spacer on, I've seen a gain in mileage of around 5 or 6 mpg, and I'd guess a handful of horsies. Nothing major, but definitely noticeable.
the electric fan mod is the best bang for the buck
bchcky said:
lots of stickers too.
Oooh, yeah, I forgot about the stickers!! I've got a GPS sticker, a Flex-a-Lite Sticker, a Quadratech sticker, a Dale Jr. sticker, and a Dale Jarrett sticker on my rig....musta added at least 100 hp with those babies!!:lol:
Dang if Folger's didn't stop making tin coffee cans, though. I tried the plastic ones for my exhaust, but they kept melting down. Instead of sounding like a violent fart, they sounded more like a sick cow having calves......:?
