Grill Supports After Body Lift
Hey folks,
Today I installed my 1" PA body lift. Everything went smoothly. I didnt bother dropping the radiator and just trimmed the fan shroud down slightly.
Anyway, my PA lift came with replacement grill support poly blocks. I wasn't aware PA included these with the 1" kit. Anyway, does anyone know how the stock grill supports come out? How do the replacement ones get installed?
I know I dont NEED them on my TJ. But I figure, since it was included, I may as well install them.
Ideas? Tips?
-Rob
If it's the same as a YJ, I think it is, they have a hole in the bottom where there is a screw holding them to the grille. May be a torx screw, good luck getting at it.
Thanks for the info. I got it out. No screw. The rubber material was just wedged into the grill. Pulled them out and installed the new one. I couldnt install them with the "bolt" the kit gives, but I just epoxy glued them into the body. Works fine. Won't be going anywhere.
Thanks for the help!
-Rob
