Clutch problem
YuriSouder
So yesterday I parked my jeep on a log and came back 3 hours later. My clutch was gone. As in the pedal was loose, there was nothing there. So I pressed it like 50 times in and out and slowly it stated coming back. It has not totally come back yet it wont. There is like 2 inches of play on my pedal now just feels wrong.
when this first happened i tried to drive it and i had it in 5th gear at about 2000 rpm's going around 30 mph. like i said i started to get better. then i had to go up a hill so i put it in 4 high and it seemed to work normal. i parked it then and hour later took it around the block and it drives fine but the clutch is not fully engaging it feels like. Is it the hydraulic lines or is there an air bubble or low fluid I am lost.
Is the clutch full of fluid (in the engine bay, near the brake booser shoudl be a place to add clutch fluid)?
I've seen some older Slave cylinders with a bleeder valve on the slave cylinder, however, if your slave cylinder is in the bellhousing there would not be any bleeder. the only fix is to replace it. even if you find a way to bleed it, it would be pointless since it's leaking, it would just suck in air everytime you let go of the clutch.
