ehhh yea, theres no way in hell your getting away with running a slip yoke or the stock drive shaft, the shackles only further increase flex over the stock ones, they allow the spring to travel farther up and down by moving with the spring, 2 inch lift shackles are kind of big and may be swaped for some angled shackles for better flex if you runt he cheapest route, fab everything yourself, look at easily 500 to 600 dollars for the slip yoke and driveshaft if you want decent quality, pitman arms off zj's give you a 3.5" drop and xj pitman arms do 2.5" drop, grab a trackbar bracket, or if you wanna do it right, get a d44 fron axle, flat top knuckles off a chevy and custom high steer it, MORE makes a knuckle for the d30 that has high steer built in
