In the summer of '09 I put a 3" inch lift on my cherokee. I know better now, but I kind of did a "bargain lift" I bought new shocks, and coil springs for the front, and extension blocks for the leaf springs in the back.
Immediately after I finished, I noticed a slight wobble in the front axle. When I sped up, and hit a bump, it would go crazy.... it felt like the axle was gonna come out from under my Jeep. Typical death wobble.
So, then began my attempts to fix it.
I got it aligned, and the tires balanced - it still wobbled.
I replaced the steering stabilizer - it still wobbled.
I bought an adjustable track bar, and got it aligned - it still wobbled.
I replaced the worn out control arm bushings, and got it aligned again - and it still wobbles.
I took it to the local 4x4 shop and spoke to the guy there - he told me that a lot of times the caster angle is incorrect when you use stock control arms on a lifted vehicle. So the second time I got it aligned i took it to a place that specializes in 4x4 alignments, and he said I should be just fine.
So, basically, I don't know what's going on. I have been told several times that the tie rods can be to blame for death wobble. So, I got down under the Jeep and had someone turn the wheel from side to side, and looked for anything to be loose. I didn't see anything unusual, but than again I'm not sure I know what to look for. The tie rod ends all looked tight, and there was no slipping, or play in any of them. The pitman arm looked the same. What should I be looking for? How can I tell if they need to be replaced?
Also, the tires are beginning to be domed on the edges.... not very badly though. It's mainly from the several times that began to wobble while I was driving. It only wobbles when I'm going +40, and goes away when I slow down to 35. It also tends to do it less when I'm in 4WD.
Any suggestions would be greatly appreciated!!
