Early CJ5 Serial number
Ia2003
I purchased an early CJ5 for $2500 last month and began the restoration. I am trying to figure out what year the Jeep was manufactured. I cannot find a serial number anywhere on the frame or body. However, I did find one on the engine block. It reads SD 807895. Does anyone know how to interpret this and figure out a year? Thanks!
Check on either the left of right side of the frame can't remember which ... It should be on the front right below the fire wall area. I'll have to check tomorrow.... Do you what motor and transmission you have in it?
My block number is sd 806279. So yours has to be newer than mine. Mine is a 56 If I had to guess yours is the same or a 57 or so....
Hello! The early CJ-5 body's were pretty much the same from 60-75 then they changed in 76. Yours has to be in that area. You need to give more info about its motor and transmission, transfer case ect. for me to tell you the year. I am in the middle of restoring a 74' cj5 myself! It has the old body style, and my serial number is on a sticker!! My sticker is located on the dash of mine right beside the steering column. I believe that's where they are supposed to be for my year. Maybe one of the previous owners of your jeep replaced the dash and relocated/removed the sticker. Just a thought, best of luck to ya for the restoration!!
I have the 4 cylinder F 134 engine with the 3 speed transmission. I am not sure what the transfer case nomenclature is but it has two sticks. The left stick has an in and out position. The right stick has 4H, N and 4L positions. I only took one picture so far but as you can see I have removed the brakes. After this picture was taken I gutted the front axle and differential for a good cleaning. I found out it has the Dana 27 up front and Dana 44 in the back. The previous owner seems to of had taken multiple parts from different jeeps and made one. The windshield is a later model with the wiper motor on the bottom. It has a "Willys" stamped tailgate. The body has a data plate on the drivers side firewall that is clearly not original It says manufactured by AM General Corp and lists a 11 digit serial number that has been semi scratched out. The grill, body and windshield are all different colors under the spray paint OD green. I am hoping to find out what year the engine is based off the serial number. It is probably the oldest and only original part on the jeep. Thanks guys! More pics to come as the project progresses.
Sounds like the t-90 3speed and the d18 transfer case .... Based on your pic I'm not sure how original the body is .. But in gonna guess it's late 50's early 60's I have the same engine transmission and tranfercase. But with a Dana 25 up front an a 44 in the rear
Matt my block number is also 806279. the serial # on top of the frame is 23319 can you give me an idea what year jeep I own and how to get the rest of the vin #. I am currently rebuilding for a hunting rig but would like to register it so it will be street legal.:???:
My serial number. Is 52596. And another number off the engine. Is 4J 152039. So I don't know what you have!! But I think mine is 56. Based on the numbers and the story I was told my the guy I bought it from ...
Sent from my iPod touch using Jeepz
Thank's for the reply Matt. Not very sure that helps but thank you. I'm actually looking for the entire vin number.
Yeah. I know. I dont have one either. Bit if you have the original plates on the fire wall. They have the whole vin number. I don't have mine they must have rotted away long ago !
Matt, if you have used the serial number info these guy's have sent you, you would realize that '62 and earlier used only the serial #. At least that's the way I understand it. I hope that's the right understanding, but I'm not sure either. Best of luck to ya brother. I'm going to the authorities to see if I can get this thing papered.
These production totals and serial number series for all Willys-Overland models, are taken from compilations handwritten by Norton Young, 1959-61. Mr. Young was an employee in the Willys-Overland Engineering Department. The figures were transcribed in 1998 by Charlie Weaver, Winston-Salem, NC, who says:
"In a talk with Norton Young a week or 2 ago, he told me that by 1961, the folks in the corner offices at K-F had no more interest in these statistics so he quit keeping them. He also said that he had difficulty getting "timely" reports from the production people, and often had to go thru the unit sheets himself and try to piece the info together. He admitted that there may be some errors." YEAR START END UNITS PER YEARCJ-2A 1945 10001 11824 1824 1824CJ-2A 1946 11825 83379 71554463 10001 16534 6534 78088CJ-2A 1947 83380 148458 65078463 16535 44050 275152WD (2T) 10001 12642 26424WD (4T) 10001 12346 2346 97581CJ-2A 1948 148459 222581 74122463 (Inc VJ2) 44051 84825 40774663 10001 13607 36072WD (2T) 12643 21859 92164WD (4T) 12347 33304 20957 148676CJ-2A 1949 222582 224764 2182CJ-3A 10001 37749 27749463 (Inc VJ-2) 84826 107895 23069663 13608 23614 10006463-VJ3 10001 12698 2698663-VJ3 10001 10654 6544x463 SW 10001 14472 44722WD (2T) 21860 26815 49554WD (4T) 33305 44062 10757 86542 YEAR START END UNITS PER YEARCJ-3A 1950 37750 63784 26034463 107896 112402 4506663 23615 25937 2322473-VJ3 10001 14066 4066673-VJ3 10001 11779 1779473 SW 10001 29616 19616 SD 10001 see SW673 SW 10001 17931 79314x463 SW 14473 17559 30864x473 SW-SD 10001 12450 24502WD (2T) 26816 27787 9714WD (4T) 44063 47709 3646473-HT 10001 14679 4679473-4WD 10001 19338 9338 90424 1951 START END UNITSCJ3-A 451 GB1 10001 54158 44158473 SW 451 AA1 10001 25906 15906673 SW 651 AA1 10001 18470 8470473 VJ3 451 BA1 10001 -- NONE673 VJ3 651 BA1 10001 -- NONE4x473 SW 451 FA1 10001 21854 11854473 HT PU 451 DC1 10001 11070}* CAB 451 DB1 10001 11070}* 1070 STK 451 DD1 10001 11070}*473 4WD PU 451 EC1 10001 26029 16029 CAB 451 EB1 10001 11894 1894 STK 451 ED1 10001 10420 4202x473 SW 451 HA1 10001 10630 630 SD 451 JA1 10001 10135 135FJ 451 GC1 10001 -- NONEJT 451 GD1 10001 -- NONE 685 LA1 10001 10663 663 685 MA1 10001 10002 2473 SD 451 CA1 10001 10003 3 *END SNs based on UNITS # - C.W. 101234 1952 START END UNITSCJ-3A 452 GB1 10001 38652 29652 " ST CH 452 GA1 10001 10013 13475 SW 452 AA2 10001 14277 4277473 SD 452 CA1 10001 12091 2091473 4WD PU 452 EC1 10001 23183 13183 " " STK 452 ED1 10001 10358 358 " " C/WS 452 EE1 10001 10056 56 " " CAB 452 EB1 10001 11085 1085 " " FFC 452 EF1 10001 11473 14732x475 SW 452 HA2 10001 10018 184x475 SW&SD 452 FA2 10001 15683 5683685 SW 652 AA2 10001 13709 3709685 PC 2DR Wing 652 LA1 10001 22819 12819685 PC 2DR Ace 652 MA1 10001 18706* 8706685 PC HT Eagle 652 MC1 10001 11537** 1537675 PC 2DR Lark 652 KA2 10001 17474 7474 92134*** *Original # of 18682 changed to 18706 by NY **Original # of 11512 changed to 11537 by NY***Reflects total with added units * and **, by CW 1953 START END UNITSCJ-3A 453 GB1 10001 20617 10617CJ-3B 453 GB2 " 37551 27551 " ST. CH. 453 GA2 " 12267 2267FJ 453 GC2 " 10065 65475 SW 453 AA2 " 14747 4747475 SD 453 CA2 " 12347 2347475-4WD PU 453 EC2 " 24128 14128 " " STK 453 ED2 " 16694 694 " " CAB 453 EB2 " 11522 1522 " " C/WS* 453 EE2 " 10008 8 " " FFC** 453 EF2 " 10146 1462x475 SD 453 JA2 " 10094 944x475 SW 453 FA2 " 20631 106314x475 SD 453 RA2 " 10992 992685 SW 653 AA2 " 17533 7533685A PC 2Dr Ace 653 MA1 " 14988 4988 " " 4Dr " 653 MB1 " 17475 7475 " " 2Dr Eagle 653 MC1 " 17035 7035 " " 2Dr Scout 653 SC1 " 10004 4 " " 4Dr " 653 SB1 " 10013 13675A PC 2Dr Lark 653 KA1 " 18205 8205 " " 4Dr " 653 KB1 " 17692 7692 " " 2Dr Falcon 653 PA1 " 13054 3054 " " 4Dr " 653 PB1 " 13117 3117675A PC 4Dr H.D.653 RB1 10001 10187 187475A PC 2Dr Lark 453 KA1 10001 10047 47 " " 4Dr " 453 KB1 10001 10461 461 * [Cowl/Windshield]** [Flat Face Cowl] 1954 START END UNITSCJ-3B 454 GB2 10001 41292 31292 " ST. CH " GA2 " 13105 3105FJ " GC2 " 10012 12475 SW " AA2 " 10188 188475 SD " CA2 " 10148 148475 4WD PU " EC2 " 13594 3594475 4WD STK " ED2 " 10185 185475 4WD CAB " EB2 " 10681 681475 4WD FFC " EF2 " 10013 13475 4WD C/WS " EE2 " 10004 46-226 4x4 SW 654 FA2 " 12645 2645 6-226 4x4 SD " RA2 " 10219 2196-226 4WD PU " EC2 " 14927 49276-226 4WD STK " ED2 " 10336 3366-226 4WD CAB " EB2 " 10439 4396-226 4WD C/WS " EE2 " 10005 54x475 SW 454 FA2 " 13528 35284x475 SD " RA2 " 10288 2882x475 (SD)Post Off. " JA3 " 10100 100685 SW 654 AA2* " 10945 945685 SD " CA2 " 10308 308475B PC 4Dr Lark 454 KB1 10001 10129 129675B PC 2Dr Lark 654 KA2 " 10026 26 " " 4Dr Lark 654 KB2 " 10282 282 " " 4Dr H.D. 654 RB2 " 10018 18685B PC 2Dr Lark 654 KA3* " 11370 1370 " " 4Dr " 654 KB3* " 11482 1482 " " 2Dr Ace 654 MA2* " 10002 2 " " 4Dr " 654 MB2* " 11380 1380 " " 2Dr Eagle 654 MC3* " 10084 846-226 PC 2Dr Ace 654 MA1 " 11194 1194 " " 4Dr " 654 MB1 " 11498 1498Dlx " " 2Dr Eagle 654 MC1 " 10660 660Cust" " 2Dr Eagle 654 MC2 " 10302 302 61389* Serials 5001-10000 for '53 conversions as "specials" [note by NY] 1955 START END UNITSCJ-3B 57348 10001 22952 12952 " ST.CH 57448 10001 11667 1667475 SW 54747 5001 10098 98* " SD 54847 5001 10098 98*475 4WD PU 55248 10001 10922 922 " " STK 55348 10001 10026 26 " " CAB 55148 10001 10058 558 " " C/WS 55548 10001 10007 76-226 4WD PU 55268 5001 22168 168* " " SYK 55368 5001 10691 5691 " " CAB 55168 5001 11391 6391 " " C/WS 55568 10001 10050 50685 SW 54727 5001 11093 6093 " SD 54827 5001 10309 5309CJ-5 57548 10001 27006 17006 " ST CH 57648 10001 10010 10 " Fire Eng. 57048-02 10001 10001 1CJ-3B Fire Eng. 57048-01 10001 10007 76-226 4WD ST CH 55668 10001 10001 1 " " Fire Eng. 55068-05 10001 10001 1 " " Amb 55068-03 10001 10011 11 " " CPC 55068-06 10001 10030 30475 2x4 SW 54147 10001 10070 70 " " SD 54247 10001 10084 84475 4x4 SW 54148 10001 11275 1275 " " SD 54248 10001 10174 174 " " C/WS 54548 10001 10006 66-226 2x4 SW 54167 10001 10845 845 " " SD 54267 10001 10226 226 " " ST CH 54667 10001 10001 1 " " AMB 54067-03 10001 10001 1 " " AMB 54067-04 10001 10001 16-226 4x4 SW 54168 5001 18095 13095 " " SD 54268 5001 10890 5890 " " ST CH 54668 10001 10002 2 " " FFC 54468 10001 10003 3 " " C/WS 54568 10001 10001 1 " " AMB 54068-03 10001 10005 5685 2x4 SW 54127 10001 10108 108 " " SD 54227 10001 10096 96 78980** * #'s beginning 5000 are just as shown on NY list. No explanation of disparity in individual units total. ** Year total shown is 360 more than the sum of the individual unit production figures. No explanation. 1956 START END UNITS CJ-3B 57348 22953 34371 11418 " ST. CH. 57448 11668 11717 49 " Fire Eng 57048-01 10008 10018 11475 4WD PU 55248 10923 11532 609 " " STK 55348 10027 10059 33 " " CAB 55148 10559 10931 372 " " C/WS 55548 10008 10613 606 " " FFC 55448 10001 10002 2 " " AMB 55048-03 10095 10104 10 " " CPC 55048-06 10012 10073 626-226 4WD PU 55268 22169 33446 11277 " " STK 55368 10692 11260 568 " " CAB 55168 11392 14458 3066 " " C/WS 55568 10051 10065 15 " " ST CH 55668 10002 10002 1 " " Fire Eng 55068-05 10002 -- 0 " " AMB 55068-03 10012 10040 29CJ-5 57548 27007 45922 18915 " ST CH 57648 10011 10022 12 " C/WS 56548 10001 10006 6 " Fire Eng 57048-02 10002 10007 6CJ-6 57748 10001 12224 2224 " ST CH 57848 10001 10002 2DJ-3A 56337 10001 12510 2510475 2x4 SW 54147 10071 10395 324 " " SD 54247 10085 10576 491 " " ST CH 54647 10001 10001 1 " " AMB 54047 10001 10004 4475 4x4 SW 54148 11276 12940 1664 " " SD 54248 10175 10397 222 " " FFC 54448 10001 10001 1 " " C/WS 54548 10007 --- 0 " " AMB 54048-03 10001 10028 28475 2WD PU 55237 10001 10004 46-226 2x4 SW 54167 10846 12190 1344 " " SD 54267 10227 10600 373 " " AMB 54067-03 10002 10002 1 " " AMB 54067-04 10002 10002 16-226 4x4 SW 54168 18096 25335 7239 " " SD 54268 10891 11650 757 " " ST CH 54668 10003 --- 0 " " FFC 54468 10004 --- 0 " " C/WS 54568 10002 --- 0 " " AMB 54068-03 10006 10013 8 " " AMB 54068-04 10001 10003 3 " " R.T. 54068-07 10001 10002 2 64270* No body designation in original 1957 START END UNITSCJ-3B 57348 34372 41591 7220CJ3B ST CH 57448 11717 11717 1475-4WD PU 55248 11533 12203 731 " " STK 55348 10060 10090 31 " " CAB 55148 10932 11087 156 " " C/WS 55548 10614 11118 505 " " FFC 55448 10003 10003 16-226 4WD PU 55268 33447 40154 6708 " " STK 55368 11261 11648 388 " " CAB 55168 14459 15476 1018 " " C/WS 55568 10066 10078 13CJ-5 57548 45923 68815 22893 " ST CH 57648 10023 10068 46 " C/WS 56548 10007 10012 6CJ-6 57748 12225 13853 1639 " ST CH 57848 10002 10003 2DJ-3A 56337 12512 13305 794475-4WD AMB 55048-03 10105 10132 28 " " CPC 55048-06 10074 10088 15CJ-5 Fire Eng 57048-02 10008 10012 5CJ-3B Fire Eng 57048-01 10019 10025 7 * FFC 55468 10050 10098 49 * Fire Eng 55068-05 10002 10006 5 * AMB 55068-03 10041 10062 22 * CPC 55068-06 10188 10290 103475 2x4 SW ** 54147 10396 10930 535 " " SD ** 54247 10577 11006 430 " " ST CH ** 54647 10002 10003 2 " " AMB ** 54047-03 10001 10007 7 475 4x4 SW 54148 12941 14250 1310 " " SD 54248 10398 10679 282 " " FFC 54448 10002 10004 3 " " AMB 54048-03 10029 10061 32 6-226 2x4 SW 54167 12191 14667 2477 " " SD 54267 10601 10838 238 " " AMB 54067-03 10003 10006 46-226 4x4 SW 54168 25336 32699 7364 " " SD 54268 11651 12230 580*** " " FFC 54468 10004 10004 1 " " AMB 54068-03 10014 10034 21 " " RT 54068-07 10003 10009 7FC 150 CAB 65548 10001 16635 6635FC 150 ST CH 65148 10001 10002 2FC 170 CAB 61568 10001 13101 310l 65417*** * No type designation given in original. From serial and model numbers, they appear to be 6-226 4x4. CW ** No body types given in original. Types shown are surmised from serial and model numbers. CW*** Original gives _7_ 80, which does not compute with serial numbers. 1958 serial number begins with 12231 indicating 1957 production figure should be _5_80. Original yearly total shown as 65_6_17, should be 65_4_17 in light of above. 1958 START END UNITSCJ-3B * 41592 48247 6656CJ-3B ST CH * 11718 11719 2475-4WD PU * 12204 12691 488 " " STK * 10191 10197 7 " " CAB * 11088 11272 185 " " C/WS * 11119 11226 108 " " FFC * 10003 10004 26-226 4WD PU * 40155 45814 5660 " " STK * 11649 11996 348 " " CAB * 15477 16969 1493 " " C/WS * 10079 10084 6CJ-5 * 68816 82877 14062 " ST CH * 10069 10136 68 " C/WS * 10013 10015 3CJ-6 * 13854 15067 1214DJ-3A * 13306 14693 1388 " ST CH * 10001 10001 1475-4WD AMB * 10133 10143 11 " CPC * 10089 10103 14CJ-5 Fire Eng * 10013 10016 4CJ-3B Fire Eng * 10026 10032 76-226 4WD FFC 55468 10099 10120 22 " " Fire Eng 55068-05 10007 10016 10 " " AMB " -03 10063 10092 40 " " CPC " -06 10291 10329 39 " " AVA " -09 10001 10001 1 " " Fire Eng " -11 10001 10022 22475 2x4 SW 54147 10931 11200 69** " " SD 54247 11007 11425 418** " " ST CH 54647 10104 10163 60 " " AMB 54047-03 10008 10008 1 " " Maverick 58147 10001 10100 100475 4x4 SW 54148 14251 14743 493 " " SD 54248 10680 10939 259** " " AMB 54048-03 10062 10070 8**6-226 2x4 SW 54167 14668 15252 585 " " SD 54267 10839 11038 200 " " AMB 54067-03 10007 10010 46-226 4x4 SW 54168 32700 39196 6497 " " SD 54268 12231 12766 536 " " AMB 54068-03 10035 10051 16** " " RT 54068-07 10010 10012 2**FC 150 CAB 65548 16636 18705 2070 " " C/WS 65348 10001 10001 1 " " ST CH 65148 10003 10003 1FC 170 CAB 61568 13102 14620 1519 " " C/WS 61368 10001 10003 3 44703 * No model deasignations given in original.** Unit totals understated by 1 (one), per serial #s. Yearly total should be 44709 on that basis. 1959 START END UNITSCJ-3B * 48248 57547 9300CJ-3B ST CH * 11720 11727 7**475-4WD PU * 12692 12924 233 " " STK * 10198 10201 4 " " CAB * 11273 11478 206 " " C/WS * 11227 11886 659** " " FFC * 10004 10004 16-226 4WD PU * 45815 53286 7472 " " STK * 11997 12506 510 " " CAB * 16970 19577 2608 " " C/WS * 10085 10090 6CJ-5 * 82878 97918 15040** " ST CH * 10137 10173 37 " C/WS * 10016 10020 5CJ-6 * 15068 17074 2006**DJ-3A * 14694 16642 1948** " ST CH * 10001 10001 1475-4WD AMB * 10144 10145 2 " " CPC * 10104 10114 10**CJ-5 Fire Eng * 10016 10017 2CJ-3B Fire Eng * 10032 10035 46-226 4WD FFC 55668 10121 10143 23 " " Fire Eng 55068-05 10017 10019 3 " " AMB 55068-03 10093 10098 6 " " CPC " -06 10330 10389 60 " " AVA " -09 10002 10002 0** " " Fire Eng " -11 10023 10024 2475-2x4 SW 54147 11201 11441 241 " " SD 54247 11426 11861 436 " " ST CH 54647 10164 10266 103 " " AMB 54047-03 10008 10009 2 " " Maverick 58147 10101 12654 2553**475-4x4 SW 54148 14744 16095 1352 " " SD 54248 10940 11079 140 " " AMB 54048-03 10071 10133 636-226 2x4 SW 54167 15253 15602 350 " " SD 54267 11039 11276 238 " " AMB 54067-03 10010 10041 326-226 2x4 Maverick 58167 10001 10130 1306-226 4x4 SW 54167 39197 47362 8165** " " SD 54267 12767 13316 550 " " FFC 54468 10004 10004 1 " " AMB 54068-03 10052 10096 45 " " RT " -07 10013 10014 2FC 150 CAB 65548 18706 21754 3048** " " C/WS 65348 10002 10002 0** " " ST CH 65148 10004 10004 1FC 170 CAB 61568 14621 17094 2474 " " C/WS 61368 10004 10005 2 " " ST CH 61168 10001 10009 9 " " Dual 61568-13 10001 10335 335475 2x4 El Goucho 58547 10001 10003 3**6-226 2x4 FFC 54467 10001 10001 16-226 4x4 AVA 54068-09 10021 10060 40 60471 * No body designations given in original.** Unit totals understated by 1 (one), per serial #s. Yearly total should be 60483 on that basis. 1960 START END UNITSCJ-3B 57348 57548 67473 9926475-4WD PU 55248 12925 13455 531 " " STK 55348 10202 10302 100* " " CAB 55148 11479 11602 124 " " C/WS 55548 11887 13337 14516-226 4WD PU 55268 53287 60913 7627 " " STK 55368 12507 13110 604 " " CAB 55168 19578 23199 3622 " " C/WS 55568 10091 10103 12*CJ-5 57548 97919 119539 21621 " ST CH 57648 10174 10325 152CJ-6 57748 17075 19110 2036DJ-3A 56337 16643 19367 2725 " ST CH 56437 10002 10014 12*475-4WD AMB 55048-03 10146 10149 4 " " CPC 55048-06 10115 10121 7CJ-5 Fire Eng 57048-02 10018 10023 6CJ-3B Fire Eng 57048-01 10036 10036 16-226 4WD FFC 55468 10144 10156 13 " " Fire Eng 55068-05 10020 10102 83 " " AMB 55068-03 10099 10209 111 " " CPC 55068-06 10390 10524 135475 2x4 SW 54147 11441 11496 56 " " SD 54247 11861 12344 484 " " ST CH 54647 10266 10355 90 " " SW Face Lift** 58147 12655 15220 2566475 4x4 SW 54148 16096 17270 1175 " " SD 54248 11080 11206 127 " " AMB 54048-03 10134 10226 936-226 2x4 SW 54167 15602 15681 80 " " SD 54267 11276 11693 418 " " SW Face Lift** 58167 10130 11097 9686-226 4x4 SW 54168 47363 56330 8968 " " SD 54268 13317 14562 1246 " " AMB 54068-03 10097 10204 108 " " AMB " -04 10004 10004 1FC 150 CAB 65548 21755 23678 1924 " " ST CH 65148 10005 10005 1FC 170 CAB 61568 17094 19599 2506 " " ST CH 61168 10010 10105 96 " " Dual 61568-13 10336 10579 2446-226 4x4 AVA 54068-09 10061 10111 51FJ-3 PO 56647 10001 10001 16-226 2x4 Traveler 54267-14 10001 10102 102 " 4x4 " 54268-14 10001 10112 112475 2x4 FFC 54447 10001 10202 2026-226 2x4 C/WS 54567 10001 10073 73FC 170 Dual 61568-15 10001 10158 158 72753 * Unit totals understated by 1 (one), per serial #s. Yearly total should be 72756 on that basis.** Note on original beside "Face Lift" says "Was Maverick". 1961 START END UNITSCJ-3B 57348 67474 85317 17844*CJ-3B ST CH ** 11728 11800 73475-4WD PU 55248 13456 13771 316 " " STK 55348 10303 10306 4 " " CAB 55148 11603 11661 59 " " C/WS 55548 13338 13360 236-226 4WD PU 55268 60914 68660 7747* " " STK 55368 13111 13522 412 " " CAB 55168 23200 25111 1912* " " C/WS 55568 10104 10114 11CJ-5 57548 119540 134747 15208CJ-5 ST CH 57648 10326 10386 61CJ-6 57748 19111 21101 1991DJ-3A 56337 19368 20909 1542475 4WD CPC 55048-06 10122 10472 351CJ-3B Fire Eng 57048-01 10037 10101 65CJ-6 Fire Eng 57048-14 10001 10003 46-226 4WD ST CH 55668 10002 10105 104 " " FFC 55468 10157 10211 55 " " AMB 55068-03 10210 10219 10 " " CPC 55068-06 10525 10559 35475 2x4 SD 54247 12345 12557 213475 2x4 Mav. 58147 15221 16422 1202* 475 4x4 SW 54148 17271 18110 840 " " SD 54248 11207 11762 556 " " AMB 54048-03 10227 15281 556-226 2x4 SD 54267 11694 19144 251 " " AMB 54067-03 10042 10116 75 " " Mav 58167 11098 11473 3766-226 4x4 SW 54168 56331 64238 7908 " " SD 54268 14562 15310 749 " " ST CH 54668 10101 10101 1 " " C/WS 54568 10101 10190 90 " " AMB 54068-03 10205 10327 123FC 150 CAB 65548 23679 24976 1298FC 170 CAB 61568 19600 21646 2047 " ST CH 61168 10106 10111 6 " Dual 61568-13 10580 10703 1246-226 4x4 AVA 54068-09 10112 10167 56 " " Trav. 54368 10001 10014 14475 2x4 FFC 54447 10202 10202 16-226 2x4 C/WS 54567 10074 10124 51FC 170 Dual 61568-15 10159 10354 196CJ-5 Diesel 57558 10001 10152 152CJ-6 Diesel 57758 10001 10128 28FJ-3 PO 62847 10001 12424 2424FJ-3A Fleet Van 62147 10001 10046 46474 4x4 Trav. 54348 10001 10005 56-226 2x4 Trav. 54367 10001 10004 46-226 4WD Dual 55168-16 10001 10038 38 66756* * Several figures which do not agree with serial numbers on original, corrected here.** No model designation given on original.This section (1961) "is the worst one for errors, there being 6412 moreunits produced, according to the serial numbers, than show on theoriginal sheets. For this one sheet I show the corrected numbers. Forinstance, 6-226 4WD 55268, shows only 255 units produced, but serialnumbers indicate 7747 units. Based on 1960 figures, 7747 seems to becorrect. Also, 475 2x4 Mav. 58147 shows only 202 units on original,understated by 1000."
you need to check for the vin number. its on the firewall in the engine bay on the drivers side, it may be hard to read but its there. once you get that there is a vin decoder on this site under the site map tab at the top.
My VIN is long gone, hence I was trying to see if I could use the engine block SN to figure out it's age.
Yah if that block is the original, *fingers crossed*
Ok so I posted the engine block serial number on my first post here months ago. How do I interpret this number and figure out the year? Thanks
