I Have An 03 Rubicon With 4" Tera Longarm And 1" Body, 35" Tires. When I Accelarate To About 25-30mph I Get A Vibration And When I Drive Slow To About 10-20mph I Hear A Squeel But Not All The Time. I've Rotated And Balanced The Tire Again And Checked For Debri All Is Good Don't Know What Else To Do Can Anyone Help?
Did the problem start RIGHT AFTER you installed the lift? If so, I would bet all my savings (all $7.42 of them!
) that your problem is the drive shaft angle. I installed a RE 4" lift on my YJ along with a Woody shaft and AA SYE kit, and the vibrations REALLY shook the Jeep at 30~35 mph (I thought the rig would come apart from the vibes!). This all ended when I changed the pinion angle on the rear to match the DS; now I have a very slight vibration that you have to pay attention to feel or you'll just think it's the engine's vibration.
Is the squeel like a rubber squeel or is it a different kind of vibration? In my case, I got a totally different vibration when slowing down that "could" be called a squeel... The reason is that under load, there is some spring warping, and that changes the angles of the driveshaft, changing the feel of the vibes.
Well It's A Rubicon So No Mods Needed Rear Is Dana44 Don't Think I Need To Mod This Monster Unless I Go In Compition But Not Going To Happen. This Also Is My Everyday Vehicle.
The mod to the rear diff is not that you will change out the rear axle, but just to rotate it. Typically, one mod will lead to another, and that one to another and so on... One mod by itself is ussually not enough.
For next time, the more information you give, the better the advice you will get. If you do not know or understand what another member is explaining, just say so and I am sure someone will explain it in a more detailed way, as they have done for me in the past. And if you do not know how to explain something, as they say, a picture is worth a thousand words! Just take a photo and post it.
By the way, this is my drive shaft angles before the fix:
And this is how it looks now:
I hope all this helps.
Felipe
PS: What's up with capitalizing
EVERY word but not using a single period???
