What's a juicebox???
its a small box with artifically flavored liquid contained inside of it. Put a small bendy straw in the top and you are all set.
:mrgreen:
other than that I don't know what one is
-Brian
I dont know if I would by one, but here is the info you're looking for
The JuiceBox is a packaged kit which contains an IGNITION UPGRADE that consists of the following components:
* New High Energy Ignition Coil w/ONE-PIECE Heavy Duty Aluminum Coil Bracket and Stainless Steel Hardware
* New Coil Pigtail
* New Large Distributor Cap with BRASS male terminal posts and BRASS tipped Rotor
* New Distributor Cap Adapter
* New HEAVY DUTY 8mm Plug Wires
more information can be found here:
http://www.driveajeep.com/tfi/index.html
I didn't see a price what will this cost?? I'm guessing under $200.
