What the largest size of tire I can replace mine with?
gotdirt
Member
I have a bone stock 2006 LJ Unlimited with stock aluminumwheels.
I have been searching and haven’t found what the largestsize of tire I can replace mine with. Currently I have 30x9.5 15 on it.
Thanks so much,
Jake
No wheeling no lift 32x10.50
Wheeling 31 x10.50
Rubbing will be on the control arm. During flex it will be on the fender.
There are a ton of variables like rim width, offset, tire width, Jeep weight, spring life, etc. JPN gave you some sound information though on the 31" and 32", great place for you to start.
Many TJ owners run 33" tires with just a coil spacer lift. Be sure to add a 3/4" spacer to the front to level the Jeep out if necessary.
