Throttle body help
Sobol
Ok so i was reading through old threads and found something on swapin a 4.0 throttle body onto a 2.5? Can it be done and what benifit would it have?
RE: Re: RE: Got nailed with vehicle inspection...need fender
definitely can be done, definitely helps with power by allowing more air in.. and definitely an easy mod
8 inch long arm
think of your motor as an air pump... the more you get through it, the more power you make... if you're going to get the TB upgrade, also think about an intake and a better exhaust system... otherwise its like trying to breathe through a straw
4.0 Throttle Body
Alright sounds good looks like i will be after one, exhaust is done itake is on order that is how i found out about the TB was looking for peoples sugestions on intakes.
now if any one knows where to pick one up cheap i would appreciate it...
junkyard! if you can't find one the junkyard up the street from me has about 3 cherokees there i could prolly track one down for ya up there...
i do appreciatre the offer i will run around sunday and try and track one down if i dont find one i might take you up on it. but i will keep you updated on the progress.
Thanks again
Alternator Ideas
ok well i went to the Junk yard with no luck on the 4.0 TB
so i will take any help anyone can give me, so dig up those ol' throttle body's i want one....
thanks
