I would greatly appreciate any help or insight! I have a 88 wrangler with a 6 cylinder. Problem occured about a month ago. Temp. would get to about 210 degrees and engine stalls out and will not restart untill it cools. Then runs fine untill it heats up again. First replaced the fuel pump with an electric Holley, then new thermostat, then ignititon control module, check ignition coil and ohmed out within specs. I was not sure what else to try so I broke down and took it in. Mechanics said it was bad floats in the carb. $320.00 later new carb and problem still exsists, however now it seems to get to 210 degrees, stalls and temp. gauge jumps to 220. Jeep seems to stay below 210 without stalling as long as its moving, but when ideling temp. goes up. Took it back to mechanic and now they have tried switching out pickup coil in dist., ignition coil, icm, and computer to no avail. They have told me that they do not get any voltage at failure on wire from pickup coil to computer. Possibly bad computer? Any suggestions would be awesome!
