Engir
Active member
I was replacing the door locks on my 87 XJ after installing the lock in the passenger side door I used the key and turned the lock both ways everything seemed fine and closed to door. Now it will not open from the outside or inside, I unhooked the rod to the lock and moved all the rods back and forth and it will not open has anyone had this happen, does anyone know a way to get the door open?
