i have a 2006 wrangler 2 door unlimited.
I am afraid to say yes SO tell us what you are thinking..
year to year and engine differences as well as electronics will put a *caveat in the answer... do not go to junk yard for a brake part
do not swap sensors, one size does not fit all, What are you looking for?
lookin to replace brake pads and rotors.rock auto does not list the unlimited 2 door model just unlimited rubicon and wrangler which i dont have. so i was curious if the same parts that fit wrangler would fit my jeep.
got me confused 06 unlimited is a 2door my mind set is 4door....
search for part number on line, or call rock and let them suggest part numbers so a mistake will not cost you...
I strongly suggest a local parts supplier to eliminate this wait and chance selection BS.
Your having to pick part numbers - you may own it fit or not ......
Attached OEM info
  • JeepPartsList2006TJbrake2.pdf
I recommend rock auto, NAPA or Brake Performance. Definitely not a box retailer.
The 04-06 unlimited is more like the 04-06 unlimited rubicon. The big difference is front axel and springs for the most part.
The 04-06 unlimited and unlimited rubicon are disc brakes all the way around. The parking brake is inside the rear disk brakes.
I just put on new brakes on my 05 unlimited this weekend. I purchased them from Brake Performance. They are lifetime guaranteed. My last set I had on there for 10yrs with no issue other than the parking brake.
Here is what I purchased. It was a bundled package with hardware for ~331 front and rear with ceramic pads. I recommend checking the parking brake and clean and lube the partaking brake lever. Check my post about emergency brake to get an idea of what part I'm talking about.
http://brakeperformance.com/brake-r...&-slotted-brake-rotors-black-zinc-coating.php
Be leery the cheaper brakes and rotors do not carry a guarantee.
Regards,
JPNinPA
Sent using TapTalk
