Ok, getting started on my lift and I got the springs off the front of my YJ except the rear bolt on the driver's side... Seems to have rusted itself to the steel sleeve inside the rubber bushing... I have the nut off, but I broke a socket trying to break the bolt loose with an impact wrench, my BFH didn't do anything, and heat from my propane torch just made the rubber melt a little...
I am thinking about trying to press it out with my HiLift jack, but i don't wanna break that too... I am also considering buying an electric cutoff wheel and slicing the eye of the spring in half, then the bolt and sleeve (once the spring is outta the way)...
Anyone got any other suggestions???
