Curious to know if anyone has done a spring over on a Cj. If so, how did you mount your front shocks. I'm using stock position on top, and a bolt welded to the spring plate on bottom.:sawzall: :welder:
If you need a longer upper mount, I believe you can use one from a Waggoneer or truck. Tons of people make tabs and shock mounts these days. One shouldn't be hard to find. Warrior Products used to have them also.
I initially used the stock lower mounts on my Waggy axle, and didn't have enough droop with my 4" lift shocks. I put tabs on top of the axletube inside the inner C and incresaed my droop dramacally. This on a YJ.
