If you Shave your head like i do you wouldn't have any hair to pull out,Haha.. Place a jackstand on the front and rear axles to get all the tires off the ground.. shift your drivetrain on 4wd and run it on 1st gear. is the howl and vibration there?, if yes, shift it to 2wd and test it again. is the howl and vibration still there?, if yes, check the rear u-joints and axle bearings. if you did not hear the howl and vibration, check the front ujoints on the driveshaft and both axle u-joint shafts..also verify your front hub and bearings are good.
