hoobness
hey guys!
the paint is stripped from the frame, and Ive learned that I need to reinforce/replace the upper pass. side shock mount. The flat-cupped support that the shock mounts to is about 1/8" thick after power washing all the flaked rust cake off. I figure the job would be easiest to do now - before the tub is on there. Plus Im POR 15 ing it.
SO anyway, I bought some 2"x2" 3/16" thick angle iron from home depot, and a flat bar of the same thickness 2" wide. Hopefully my creativity will kick in...
Has anyone had this problem? If so could you describe what you did to fix it, even better if you have a picture! I looked for pre fabbed mounts with no luck...
help would be great, thanks again.
