disc brake rear
yjdave
RE: dana model 30...
Is anyone running disc brake rearend? Having problem with brake pedal being soft...NO AIR IN THE LINES...Think it is the M/C..Do i need a different one than stock....By the way everything is new.........
What kind of rearend is it? I've been told by a few people who have put Ford 8.8" rearends in with disc brakes that they've had to install a master cylinder from an E-350.
You may need to remove the check valve ball from the master cylinder or proportioning valve. Remove the rear brake line and you'll see a metal seat with a ball behind it. Remove the seat with a self-tapping metal screw, remove the check ball, and reinsert the metal seat. Reattach the brake line and bleed.
RE: Re: RE: girl + jeep
yup.....what they said. I've researched that conversion for my TJ and I've seen answers similar to both of those all over the place.
