If the coolant system has not got a leak and you are looseing coolant there is very few places it can be going. Leak has extrenal or interenal. External is bad and can be fixed via radaitor, heater core, hoses, ect... Internal can be a cracked block head ect.. not so ez to fix. Check you oil for white foam on the dip stick and or under the oil fill cap. Check you exaust for steam. hopefully this will help. tug
