Coil spacer install....
LGR
So, I got some teraflex coil spacers in the mail today. I ordered 3/4 inch ones but they gave me 1 1/4 inch. Normally i wouldn't say anything, but...
I have a TJ with 4" skyjacker suspension lift, 33" tires. SYE and CV shaft. Now if I put in the 1 1/4 coil spacers will i have to change my shaft or breaklines? I did change the breaklines during my 4" install. I mainly don't want to have any problems later if I put in the larger spacers. Just clear my head and put me on the right path!
unless your 4 inch kit came with adjustable upper control arms you are probably going to get some pinion vibes and beware of death wobble. I put 5.5 inch springs in and I got a really bad case of dw. You most likely will need to upgrade to a long arm kit.
That much increase on the stock shortarm suspension geometry is too much, the control arms will be WAY too steep. Save those heights for a longarm suspension.
Dang it, now I gotta upgrade to long arm. How easy is that? Does RE make a upgrade for long arms? even though i'm running a skyjacker suspension. Nothing can be easy.
