clutch?
OhioMike
so i go to drive it down the roda...and the clutch does not disengage...
the fluid is full...there does not see to be leaks...
it sat up for about 3 months...air in the lines?
ok i checked for fluid gettin to the master and slave cylinder...they are...so unless someone else has ideas...i;'m gonna pull the transmission adn look for damage...maybe i bent a finger on the pressure plate ro somethin...i dunno
i'm pretty mad at this point...
RE: Free 4.0 block and cheap parts.......
You could have a leak inside the bellhousing at the slave if it is internal
i talked to the previous owner...we work together...apparently it does this all the time...i remember him tellin me about it when i bought it but didn;t pay mucha ttention...he says it goes through slave cylinders like mad...
what would cause that...he says it took the shoip he took it to 5 tries to get it to work...
how hard is it to swap to a manual clutch...aint no chics drivin it...
cherokee console removal
On my dad's scrambler (which is rarely driven) the clutch plate has rusted to the flywheel a few times after it sat up for awhile. Did this happen WHILE you were driving it or when you went to start it?
RE: cherokee console removal
when i started it the first time...but he says it took the shop he took it to 4 or 5 tries to get it to work...and i had the cluth out when i rebuilt the engine...so i don;t think it would be rusted to the flywheel...
