Bronco 44 in my TJ
phatyaspen
Offered a bronco 44 front... I know i would need perches and regear it but where do I find disc brakes for it? Someone has to know
The cheapest place would be the junkyard. Find a disc brake equipped Ford with a D44 front and the lug pattern you want and get all the hard parts, then go to the store and buy new replacement calipers, rotors, and pads for the vehicle you got the parts off of. I'm not sure whether you do or not......but you may need to use the stub shafts from the disc donor too.
White said:
ford used the radius arms too. Have to cut them off.. A 79 bronco has disc front 44.
66-74 didn't! 79 also has that stupid twin I beam crap too, or did Ford make that mistake in 81??
I think the "I" bean was later, Remember the bronco we cut up. It was a solid 44.
twin I beam is the stupidest excuse for independent suspension that any automaker has ever come up with
