Aussie locker installation
YJTino
Tire sizes
I started installing an Aussie locker in my Dana35 today. I know that some of you did installed Aussie lockers before. I’m off on the tolerance accepted by the company between the spacers and the pinion shaft. Tolerance should read between .006 and .020. The gap on mind is .025 witch would affect the warranty if installed like it. They suggest worn thrust washers or case. I’m hoping the washers are to blame. Is anyone would know how thick those are suppose to be? Where to get new ones?
Thanks
