anyone heard of 1984 dodge 3/4 ton axles under tj
Jimbo86
I found a set of 84 dodge running gear for my tj, dana 44 front, 60 rear, and i was wondering if the front will clear my driverside spring perch, and in doing so if the axle will sit even under my front end? the axles are 64 1/2" in length, and Im not sure how much more offset the front diff would be. has anybody out there ever heard of a dodge setup like this under a jeep? or if it will even work?:???:
Back then Dodge used a right side drop front diff, TJ's have a left side drop.
But either way, it will be a custom suspension so how it sits under your TJ is a matter of who and how the front suspension is made. Because of the opposite side driveshaft Dodge & GM front axles are not the first choice when it comes to swapping into a TJ. You will need a Chevy, Dodge or CJ transfer case to move the driveshaft over.
