I've just outfitted with on board air and have run 1/2" ID truck air brake line from front bumper to rear and added quick couplers at both ends for convenience. My tank is now mounted on the driver's side fender inside the cab. I'm a little nervous about having a pressurized tank inside the cab but couldn't find any other place for the tank, as it seems too long for the driver's side underneath between the frame and drive shaft. How do I run the air brake hose into the cab? The hose is too stiff and big to make a 90 degree bend from under the body to up and through the floor boards. Do I need a 90 degree brass fitting or what? Anyone else plumbed this stuff before? Any magic tricks or ideas you can share?
