ABS
jeepdude832
I had a super 35 installed and because there were no abs gears on the new axle my abs light is on and my front abs doesnt work as a result. Is there any way to bypass the rear sensor so the light will go off and the front will work again.
bushwacker extenda flares
you will need to pull the abs fuse if you want the light to go out, but to be rid of the ABS requires you to change the master cylinder.
