Jeepinaround
To recap the video, we have an intermittent cylinder 3 misfire causing rough idle and stuttering / hesitation at low RPMs. Once we pass 2,000RPM, the truck drives perfectly. So far, we have checked the following:
Replaced all 6 fuel injectors with OEM
Checked all spark plugs, all gap within range installed 2 years ago
Checked coil for physical signs of damage – did not functionally test
No vacuum leaks
Engine compression – all within spec, changed throttle position sensor, cleaned idle air controller, replaced
Unplugged 02 sensors, problem did not go away
Fuel pressure test – results in video, is this normal?
Fuel pump is 2 years old – it drives fine at high RPM, does that rule out pump?
Thank you for watching, appreciate all the help in advance
