yj doors
88jeepn
i just bought a set of full doors for my yj and on the yj doors it has the little peace of glass that flipps out and inn does any 1 no if i can put the tj style glass in my yj door so i dont have to have the thang that turns
Do you mean that you want to use TJ uppers on your YJ? If that's the case then it probably won't work. I believe that the windshields on the CJ / YJ are at a different angle than the ones on the TJ.
correct, you can not swap the tj glass for the yj glass, doors have a different rake to them. you could get custom glass cut though, problem would like in finding the correct window channel to have it work properly. best solution.. Take the door off, problem solved
alright thanks man
nah im talkin about the glass for the full doors
